HP DesignJet 500 and 800PS
I am currently running into a issue with the HP print driver used for the HP DesignJet 500 and 800PS. If I go into the windows printer properties and add the architectural size to the paper list they show up in windows then I go into BricsCAD select the plotter then in the scale/view tab go to select my arch C size paper it is not listed. Where does BricsCAD read the paper size list from? Is anyone else having this problem?Thanks.
I get to answer a question for TINA!!!!!!!Cool, howeverOurs are set up in ANSI, so I have not a clue!Sorry
I own a Designjet 500 and have the same problem with "Bricscad Paper sizes" in the original plot dialog. I need the selection 'oversize D - 24'x36" and Bricscad just offers up to 'D size: 22"x34". This is one for the Bricscad support and development team..........
Make sure the paper size in Icad is set to 36" roll. Then go tothe bottom of the Paper Size list to : <>.Make sure there is a check mark next to Architectural. Be sureto save your quick setup for use later, as well as saving your setup in Icad in case you need to reset it later. I specify the size and color settings as : HP500_24x36-gray , etc. for a quick settings restore.
Oops! Syntax error - The end of the Paper List says: Edit Paper List.
