Error during EXPORT to format DXF 2004
Command EXPORT to format DXF 2004 is not work properly.After export an error message a appears:"Error writing file. Save attempted to incompatible version."Tested on new version 6.0019.
  • Try using the Command "SAVEAS", and in the drop down menu choose the option for (Ascii/Binary) dxf with the flavor of version 2004.
  • We confirm the problem. The export command does not yet save to format 2004. This will be fixed in the next major upgrade, scheduled for this summer.kind regards,Alexander Van Heuverzwyn,Bricscad
