Slow Launch (Bricscad) on a workstation
This is possibly a hardware issue, butOne of our workstations is taking longer and longer to launch. (Almost 1 minute - while mine is almost instant) Machine is a P4, 2.4Ghz with 512mg Ram.Is there a fix or repair that I can try.
You might check what is starting and runs on the computer and compare it to other.You can download a small program called StartupCPL.zip and install it. With this program (which is installed in the control panel) you can see and change what starts on the computer.Search for "startupcpl" e.g. in Google and you will fin places to download it from. (It is a free program)Svend
