Entity selection
This must be a simple one but I can't seem to find the solution:When I select a few entities in a drawing (manually, by mouse), and I do a second selection which overlaps the first selection, the elements that were selected previously, become UN-selected. Is there a system variable or setting that disables this 'toggle' effect? I want to keep all entities selected.TIAArno van Eeuwen
The select / deselect behaviour that you describe is not controlled by a system setting. Moreover, this behaviour can be very helpful in some situations. If you want to add entities to a selection set, whithout deselecting already selected entities use the SELECT command. The SELECT command is launched automatically when an editing or manipulation command is started without preselecting entities.
Thank you for clarifying. This will help many of our users.
Hi,In fact there is a system variable called PICKADD.If this is set to On or 1 it let you pick and add entities.If this is set to Off or 0 you only select one entity an the previously selected wil be unmarked.Just type in pickadd and press enter.Svend
