Crash by using "explode" V6.2.0020
System crashed by using "explode" command in Paperspace.Release: bricscad V6.2.0020 pro - englishIf you use that command on a Text-Attibute to explode it, the system offers 3 choices:"Save changes - YES - NO or CANCLEIf you select Cancle the system went to a sleep mode with no further resopnse.if you select YES or NO the system shoots down.
  • Correction to crash by using "explode"This male function occurs only when the file "icad.fmp" (IntelliCAD Font Mapping File) is in use.
