EXPLEVEL system variable
Hi, I'm a Bricscad developer and currently studying how we can improve the Settings and Option dialogs, and the menu/toolbars customization. In Options>General, there's a setting "Experience level" (Beginner/Intermediate/Advanced). I wonder if this option is frequently used? We might want to remove the option altogether. Instead, we could provide a similar functionality via Customize>Import/Export.Any thoughts?
  • Most people don't know about this system variable.BUT the EXPERT variable is impoprtant and used by many.It's very annoiing when today's developers of another dwg based cad program don't use it in new commands...
  • I'm only a recent convert to BricsCad, but mine is set to Advanced and will probably stay that way, so to me it wouldn't matter if it moved.
  • Forgot all about that, need to kick everyone up to exp.What would be the default?
  • I could never see much point in anything other than Advanced... even for dummies (like me).
  • OK, it seems that this setting could safely be removed... the default would be Advanced, of course. I will check if we can add the EXPERT variable instead.Thanks all!
