leader arrows
When I have an existing leader with a filled arrow and I copy, move, or try to manipulate it using the grips, the arrow head changes to the current color that I have selected (the lines remain the same). The colors in my dimension setting are all set as colors and not by layer or block. If I open the drawing in autocad, the colors go back to the original setting, but are changed again when I re-open it in Intellilcad. It doesn't seem to be affecting the line weights when I print, but is kind of distracting when I'm working on a drawing. Does anyone else have this problem?
  • I have had that in the past, they changed to the current layer. But the problem went away after about Icad-2000 from memory, anyway haven't had it for a long time.
  • John, thanks for the reply. I'm running 6.2.0020 and I've only noticed it rescently. Didn't know if there was some obscure system variable that controlled this. As long as I don't touch the leaders it will stay the original color, but if I move or copy it the arrow only changes to the current color that I have selected. It's more of a distraction than a problem at this point.
