Next version
Anyone know when the next version of Bricscad is due outand what improvements can we look forward to? I'm alsoin the process of coming up with a lisp routine that will changethe titleblock info in (x) amount of drawings all at once.Maybe someone knows of such a routine already createdand where to find it.
I"ve been wondering a bit about that myself. I am creating an application which needs to make use of attributes to create a Bill of Materials.When I saw what versions of AutoCAD were supported by IntelilCAD (BricsCAD) I had orgiinally assumed they would also support most of the features of those versions. However, the current version of BricsCAD does not support tables or even OLE of a spreadsheet. I would love to plan on using these features if they were available.As for Attribute editing, I've seen some of those kinds of programs, but they are written for AutoCAD. Personally, I've not had a lot of luck using AutoCAD programs in BricsCAD. If you go looking, look only for LISP programs as that is your only hope of finding something that may work.Joe Dunfee
Here is an article on Attribute Manipulation using LISP or VBA with AutoCAD;http://manufacturing.cadalyst.com/cadalyst/article/articleDetail.jsp?id=91001&searchString=manipulating attributesJoe Dunfee
