PICKBOX
Anyone else having my problems ?Mostly annoyingSupport cant repeat´.BricsCad received following Support Request from you:[2006-10-17] HelloSince the introduction of V7 I am again having problemswith dissappearing pickbox an aperture.This used to be a problem years ago but dissapeared.Repeatable by using this LISP and escaping half way through.(defun blinss ( fpath / char cnt bn)(setq cnt (1- (strlen fpath )))(setq fpath2 (substr fpath 1 (- (strlen fpath) 4)))(while (/= "\" char)(setq char (substr fpath2 (1- cnt) 1))(setq cnt (1- cnt)))(setq bn (substr fpath2 (1+ cnt)))(if (tblsearch "BLOCK" bn)(command ".insert" fpath pause 1 1 pause)(command ".insert" fpath pause 1 1 pause)));eofSyntax for use ( in a menu)(blins"X:\drawings\blocks\blockname.dwg")I loose the pickbox in moore ways but this is the only one that I can pinpoint as repeatable.I have a little icon to reset the pickbox and aperture and now it back in frequent use.Kind regardsPatrik
Bonjour,I confirm this bug is happening so often that it is even difficult to keep concentrated on work.My config is perhaps specific in that sense that I use a 2ble screen graphic card. But I guess this has nothingto do with the issue.Previous posts are a little bit helping, but not sufficient.Especially when you are drawing a long polyline entity, and that you get stuck in the middle of the way!In this specific case, is there a possibility to create a transparent macro-command as to reset the OSMODE to a workable value (snap widget getting visible again) withoout losing the job made in creating the first segments of the polyline?Are there some LISP and/or VBA snippets available on this kind of issues?Thanks on forward
HiI have done a script file called MyVariable.scr that i launch regularly during a drawing session. And the problem mentionned above is much less important (in my case)There is:filletr0osmode0pickbox2aperture4elevation0dimtxt0.44viewresno50blipmodeonpdsize0pdmode0savetime12snapang0regen_STOPSCRIPTRichard Stas
