XREF path not working!
The path for XREF's isn't saved between sessions in version 7.1.0012. Also, the XREF path does not work. Everytime you try to attach an XREF it defaults to the BLOCKS path.
It would be nice if the paths to xrefs and blocks defaulted to the last path used. I don't believe they ever did in Intellicad.
The same here (version 7.1.0012).I've tried also to set the path with tools>options>Path/files with no result.
I see the same thing in 7.1.0016. I have set through the tools->options and attempted directly via the registry but on each opening of BricsCAD it is reset to temp folder.Any solutions?Thx.Tim
