Memory leaks..
Image tiles in dialog boxes still leak memory resources, in addition to having other problems when displaying slides. Changing the slide in an image tile automatically replays the previous slides shown in that tile (in the same dialog session). This severely slows down performance and seems to be what causes the memory leak. Is a corrupted cache mechanism at work here?There are also some problems with the ACI background colors. I wish Bricsnet could fix these problems now (been complaining about them for more than a year). If you need a good test utility, try this one:http://www.cadalog.com/file_info.phtml?file_location=/blockman/Blib.zip&filename=Blib.zip&rowcolor=ffffccTry connecting to a block folder with more than 12 dwgs, page back and forth a few times to see the behaviour i'm complaining about.
