transferring V8 onto a new pc
I have an old pc, and have upgraded to a new one. I want to load Bricscad V8 onto my new pc, but its not allowing me past the licence key window. I enter the licence information, but it still does nto let me past. why is this? and how can I get v8 onto my new pc?RegardsGraham
  • Such behavior is strange. You're sure the code you are using is correct?I have installed a second copy on my laptop (see EULA) and never had a problem installing V8 twice. Then: the version installed on the laptop is not the latest update of v8, so I cannot confirm that installing v8.1 works flawless.Gerrit
  • Where would I get my licence key information in order to check it?
  • Please file a support request for this licensing issue, we will help you out.
  • Reason I ask to file a support request is that I want to ask you which license key you entered, but that information should not be made public: others should not start using your key...
  • Try this,Start icad.exe from the Explorer by right clicking and choosing Run as .... / Run as Administrator (depending on OS). In the dialog Run As uncheck "Run this program with restricted access" and press OK. Then Enter the license key when asked for it.You only have to do this once, then it works.Regards,Arnold
