BricsAD Object
Hi. When I open a document with a object of AutoCAD, the objet is not associated to BricsCAD.Are you know the entry in registry of windows to reate the association?
  • You can right-click on a DWG, DXF, PGP, PAT, LSP, or any other type of file in Windows Explorer or My Computer and select "Open with" and then "Choose program..."Check the box that says "Always use this program to open these files", and then select BricsCad from the pull-down list. If it's not there, or if you want to specify which version of BricsCad to use, click the "Other" button and find the EXE file in the Brics folder in C:\Program Files.
  • Thank`s but thisn't solution.I want open a Object of AutoCAD inserted in OpenOffice.org.
