XREF Disappears
A new Xref problem (on top of my existing one). When I go to make a new XREF in the hopes that it would solve my display problem in AutoCAD, the xclip makes the entire XREF disappear, not just the stuff outside the box I drew.Is there a setting I set by accident that is causing this? I updated to latest version but it did not fix this.
  • I just tried a couple and they xclipped OK. Very slow to insert xrefs using the command line, but OK using the xref manager. I don't know of a setting controlling the appearance apart from xclipframe.
  • I am not sure whats up so I just removed version 8 and went back to Version 7. I had no problem with xclips in that version.
  • Thanks for bringing this to our attention: we indeed noticed an intermittent problem when defining rectangular xclip boundaries. A fix has been applied, it will be included in the upcoming V8.2 release, scheduled for next week.
  • Just getting back to this. Latest update I downloaded did fix this problem.I think I can now stop using version 7.Thanks.
