Loading applications at startup
I could not find a way to load applications at V8 startup, like I used to do with ICAD.SDS in V7 or ACAD.RX in AutoCAD. Is there the same functionality in V8? If so, what's the file name?Thanks in advance.
Buonanotte Gianni,this knowledgebase entry should shed some light:http://www.bricsys.com/common/knowledge/topic.jsp?id=222HansBy the way, sincere and heartfelt thanks for the outstanding Nardini.
