Image Manager browing issue...
When running the "image" command to change the path of previously loaded image files, which have been moved, the dialog does not show the files by default. The file type filter says "Image Files" but I cannot see any unless I type in the "*" wildcard. I am using BricsCad v8.2.8 build 10972 on Windows 2000 Pro.Thanks you.
