Select objects
Questionhow can i select objects (with a selection window) that are only green?If i use the dialog properties ( think it is shown as properties in the english version because i use the german), and i select colour and then green , all green objects are selected in my drawing. but i would only select the green objects in my selection window.i dont´t want to klick on all lines, text etc. because it isnt funny :-))HOW?
To select entities of the same color that exist inside a window selection you can do the following:1. Launch the select command2. Choose SELECT BY PROPERTIES from the options3. Choose COLOR, then the color you want to be the selection criterion(all entities of this color are selected now)4. Choose SUBTRACT FROM SET from the options5. Choose LOCATION from the options6. Choose one of the OUTSIDE OPTIONS (window, polygon, circle)(all red entities outside the WINDOW, POLYGON or CIRCLE are subracted from the selection)Regards,Louis
