"pure virtual function call" error
When i'm creating 2 linear dimension and one of them intersect with each other, the application crash and a message says "R6025 : pure virtual function call" and ask me if i want to save my files or not, has anyone came accross the same error with me ? Any solution would be very appreciated, thanks.
In V9.1.8 an issue with associative dimensions has been fixed that sounds quite similar to what you describe. Please download the most recent Bricscad version (V9.1.9) and see if this solves the issue. If the problem persists, please file a support request and attach a sample drawing along with a description of what we should do to reproduce the problem: we will be glad to fix it and add an automated unit test for it.Kind regards
