Cycle through entity snaps
Hello,BricsCAD v9 Help states that when snapping to geometry it is possible to cycle through the relevant entity snaps (assuming you have more than one of them set) by pressing the TAB key. This does not seem to work. Is this a known issue or might there be something wrong at my end?Thank you,Phil
I didn't know about that, but I just tried it and it seems to work for me. The only problem is that the written cursor cues don't change to reflect what's happening. But tabbing definitely seems to make one of the active osnap settings the only one, or maybe the preferred one. And repeated tabbing seems to cycle through them. The red squares and triangles and X's give some idea of which of the active osnaps each tab selects, though sometimes one or another of them won't appear when it should, or will just flash on briefly.
This has been corrected in the latest beta release, V9.2.2, currently being tested.V9.2. is scheduled to be released in the coming weeks.Kind regards.
