Bricscad Video Tutorial
Hi Andy,Very helpful....Thanks
But I cant found 3D tutorial...Have you a link ?
Not sure there ever was one on the Bricscad site but take a look at pages such as...http://www.cadtutor.net/tutorials/autocad/index.php?category_id=4http://www.caddigest.com/subjects/autocad/tutorials/3d.htmfor a start
Looks like 3D feature in Briscad is limited compare to autocad 2009.What do you think Andy... ?
I've not used Autocad at all so can't really comment on comparisons.I have found it relatively easy to create 3D objects and manipulate them from 2D objects within Bricscad but wouldn't use it to create anything as complicated as a 3D building or piece of engineering work.There are other tools available for such things, eg. Architecturals for buildings and an add-on mentioned here recently for engineering.
I don't have Autocad, but do use Bricscad for 3D.I am curious... What feature(s) do you miss?I only miss good material/lighting/rendering in Bricscad. Now investigating 3D Toolkit from http://www.dvgarage.com/ as a rendering companion.Acis Out from Bricscad V9 can't be read into 3D Toolkit.3D Toolkit Modeler can read acis files (.sat) from Bricscad V7.1
