Esnap
Hi,Wanted to know where can we find the "FROM" command which we have in AutoCAD for giving reference point. In AutoCAD it appears in Osnap but its not there in BricsCAD.ThanksSanjay.
  • Please read the "Enabling From or Ref Point on V8" item in the Bricscad Help.You will find it in the User Guide under "Drawing Accurately".
  • Hi Louis,Thanks for u'r reply as per u'r instructions i had gone through the help there is the lisp code which i have to paste in notepad and save it so that it will start as startup along with bricscad but inspite of this why don't you put up in ESNAP menu itself like EndPoint, MidPoint etc. so it becomes quite handy to use.ThanksSanjay.
