Some bugs ?
Hello,Just 2 or 3 problems I found in V9.2.7 :1)(vlax-put entVBA "Coordinates" lstcoords) => doesnt work like in Acad : need to do : (setq var (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length lstcoords) )))) lstcoords) ))(vla-put-Coordinates entVBA var)2)(initget " ") then (entsel) and [ENTER] returns "" in Acad, but NIL in Bricscad3)"change" command : if a block has attributes and you use the "change" command to change its layer, then the attributes layer changes as well (not in Acad)4)ssget : if I do for example : (ssget (list '(0 . "INSERT"))) then select some blocks that are part of some groups, all the entities of the group are selected as well (not in Acad) : need to set Pickstyle=0 before selecting.Can you confirm ?ThanksPhilippe
This forum is meant for communications among the Bricscad user community, for communications with the Bricscad development team please use Support Requests.May I kindly ask to file the abovementioned issues as a Support Request, your request will promptly be assigned to the appropriate analyst.Thanks for your understanding, and for helping us to make Bricscad a better product!
