Crash report files...
Hello,I wonder if someone from Bricsys could comment on the crash report files.Is it beneficial to Bricsys for us to send them in as a support request if there is no repeatable, documented procedure to trigger a crash or does this just create noise for the support personnel?What can we do to assist you in identifying flaws that do not have easily identified simplistic procedures to cause a repeatable faults?Are there additional levels of logging possible?Should I wait until I have a documented and repeatable procedure before reporting a crash?Thanks.
When we succeed in reproducing the problem a crash report is not needed. It's when crashes are erratic or difficult to reproduce that they become valuable. Usually the crash report is small and attaching it to a supportrequest is little effort.
Ok, great. I will send them in. That was my original thinking and I have been sending them in when I find them. I was uncertain if this was helpful or not in the cases I was unable to provide files and scenarios that reproduced the crash. See SR 18420 for one recently sent in.Thanks for the clarification.
