Bricscad in Terminal session
Hi,I have a problem to work with bricscad v8 in terminal session. When I select many objects and press delete the error message is "The memory could not be read". After that I have to close file. Please help!
  • In some previous versions, it was better to issue the command first then select the objects if there were more than a few objects. I don't have that problem any more in V9.
