Selection one of entities, they are on each other
How can I select one eg. line, that is just under second one? In Autocad we used CTRL + click on the enentity.
  • You can use the following trick:Select both entities using the 'window overlap' method.Press and hold the shift key, then click on the entities again, which will unselect the top entity. The bottom entity is the only one selected now.
