Visibility States Not Working In Parametric Block
in 3D Modeling
I'm working on a parametric block that contains visibility states, but the visibility states don't work after I exit the Block Editor. They worked before I converted it as a block, and they worked while in the block editor, does anyone know why they wouldn't work after that?
0
Hello.
It is not clear what happens - the workflow could be quite complex.
Something you could experiment with is like this:
- Create a fresh new drawing and add the geometry and visibility states - this is the block structure.
- Save this drawing.
- Create or open the main drawing and insert the previously created drawing (the block).
This approach will ensure that the entities and parameters in the block are not mixed with other entities or parameters in the main drawing.
0
