Revolved solid showing as jagged/segmented not smooth
Don't know why it's doing this in V26 but it's really aggravating as V25 didn't have this issue. See screenshot attached. Revolves are rough and segmented. In the past viewres and a regen helped but not here. Viewres/curve quality set at 15000, Facetres set at 10. What am I doing wrong?
  • Could you attach an example drawing here? Screenshot is missing in your post.
  • Oops! Sorry Lyubov. Top view of revolved cylinder in white. The 2D circles are fine so don't know what is going on.
  • You can try the next settings instead of FACETRES: Use FACETRES system variable (SpaUseFacetRes) = 0, Surface tolerance (SpaSurfaceTol) = -0.25 and Normal tolerance (SpaNormalTol) = 10.
  • Yes that seems to look much better thanks!
  • You are welcome )
