Solid Modeling behavior and other annoyances.
I have a few things that I have been working around and hoping someone can clue me in on how bricscad treats these items.
  1. When I'm using the "SOLIDEDIT" command, and moving or coping faces. I loose the USC or the ability to use my ortho to pull the direction and enter in a distance. Autocad does this and I use it all the time. Anyone else have this issues or know of a solution? using Microvellum BSB, that is on Bricscad V25.2.008.
  2. When drawing a line over top of another line or solid, when I select the line it always picks the bottom line, not the newest line. so if I'm using a line to reference or for a new element it picks the one below, it's a bit frustrating. I have even tried draworder but doesn't seem to help. Any ideas?
  • Draworder, or the concept of which of two lines (or anything) at same Z, is on top of another, only works in visualstyle Wireframe i.e. doesn't work in any modelling style.
  • I just find it strange that it always selects the bottom line, and with 25 years of autocad, it's never the bottom line that I'm trying to select. 🤣
  • any idea why the ortho doesn't work when in the solidedit command? usually, I can pick a reference point and pull it the direction I want to go and type a distance. i'll let me select a point, but no ortho tracking and the cursor guide lines just disappear. Specifically in Solidedit, Face, Move. (it works Solidedit, Face, Copy).
  • 'the bottom line' - you mean the earliest placed line?
  • actually it will select anything, but the last line drawn. typical cad behavior at least in AutoCAD would select the last line drawn.
