Dose Bricscad have a native command to draw tin surface long section from path (2d polyline)?
I am pretty sure have posted before have a look at "Civil Site Design" does way more than a long section, auto make layouts of the long section given Hor and Ver scales, with plan view also on same layout. Compatible with Bricscad.
0 -
Python, but maybe this will get you close, maybe you can use AI to port it to lisp. The compute of baseline_z seems off though, I don’t know how to compute it, so it’s magic 900
from pyrx import Ap, Db, Ed, Ge, Rx import traceback import math def get_2d_profile_data(polyline: Db.Polyline3d): """ Computes 2D profile graph coordinates from a 3D polyline. Returns: (station_distances, elevations, points_3d) """ points = polyline.toPoint3dList() station_distances = [0.0] elevations = [points[0].z] # Extracted first item's Z elevation cumulative_distance = 0.0 for i in range(len(points) - 1): pt1 = points[i] pt2 = points[i + 1] # Calculate flat 2D segment length in the XY plane dx = pt2.x - pt1.x dy = pt2.y - pt1.y segment_length = math.sqrt(dx * dx + dy * dy) cumulative_distance += segment_length station_distances.append(cumulative_distance) elevations.append(pt2.z) return station_distances, elevations, points @Ap.Command() def drawprofile(): try: db = Db.curDb() # 1. Select the alignment 3D Polyline ps, id, _ = Ed.Editor.entSel("\nSelect 3D Polyline: ", Db.Polyline3d.desc()) if ps != Ed.PromptStatus.eOk: raise RuntimeError("Selection failed.") # 2. Ask where to draw the new profile view in your drawing p_status, insertion_pt = Ed.Editor.getPoint("\nPick insertion point for profile view: ") if p_status != Ed.PromptStatus.eNormal: raise RuntimeError("Insertion point required.") # 3. Process the polyline data pl = Db.Polyline3d(id, Db.OpenMode.kForRead) stations, elevations, _ = get_2d_profile_data(pl) # 4. Determine adaptive baseline datum below the lowest point min_z = min(elevations) max_z = max(elevations) vertical_spread = max_z - min_z if vertical_spread == 0: vertical_spread = 10.0 baseline_z = min_z - (vertical_spread * 0.5) # adaptive baseline seems wrong baseline_z = 900 # Open current space for writing database entities btr = Db.BlockTableRecord(db.currentSpaceId(), Db.OpenMode.kForWrite) profile_graph_points = [] # Define text sizing parameters relative to your landscape's scale # Adjust text_height if labels appear too small or large in your viewport text_height = vertical_spread * 0.05 if vertical_spread > 0 else 2.5 text_offset = text_height * 0.5 # 5. Generate and draw profile lines & text labels for i in range(len(stations)): # Map 3D Chainage -> Graph X | True Elevation -> Graph Y graph_x = insertion_pt.x + stations[i] graph_y = insertion_pt.y + (elevations[i] - baseline_z) top_pt = Ge.Point3d(graph_x, graph_y, 0.0) base_pt = Ge.Point3d(graph_x, insertion_pt.y, 0.0) profile_graph_points.append(top_pt) # Draw the vertical station drop lines (Light Gray) drop_line = Db.Line(top_pt, base_pt) drop_line.setColorIndex(9) btr.appendAcDbEntity(drop_line) # --- ADD STATION TEXT LABEL --- # Text position directly underneath the baseline axis text_pos = Ge.Point3d(graph_x, insertion_pt.y - text_offset, 0.0) # Format display string (e.g., "Sta: 140.50 | El: 923.40") label_string = f"Sta: {stations[i]:.2f} El: {elevations[i]:.2f}" txt_ent = Db.Text() txt_ent.setPosition(text_pos) txt_ent.setHeight(text_height) txt_ent.setTextString(label_string) txt_ent.setColorIndex(7) # White/Black adaptive text # Rotate text 270 degrees (-90) so it drops cleanly straight down without overlapping adjacent labels txt_ent.setRotation(3.0 * math.pi / 2.0) btr.appendAcDbEntity(txt_ent) # 6. Draw the continuous ground boundary across the top (Green) ground_line = Db.Polyline(len(profile_graph_points)) for idx, pt in enumerate(profile_graph_points): ground_line.addVertexAt(idx, Ge.Point2d(pt.x, pt.y)) ground_line.setColorIndex(3) # Green btr.appendAcDbEntity(ground_line) # 7. Draw a solid baseline path boundary across the bottom (White/Continuous) base_line = Db.Line( Ge.Point3d(insertion_pt.x, insertion_pt.y, 0.0), Ge.Point3d(insertion_pt.x + stations[-1], insertion_pt.y, 0.0), ) base_line.setColorIndex(7) btr.appendAcDbEntity(base_line) print(f"\nProfile view and vertical labels successfully drawn.") except Exception: print(traceback.format_exc())0 -
Thanks for the replies.
I have a lisp that do it.
I was actually wendering if bricscad V26 have a native command to do it,
so I dont have to use lisp or 3rd party app.
@ALANH - see this discussion, mybe that is the discussion you ment?
@Its_Alive - thanks, I'll try the py code.
0 -
@Its_Alive A couple of comments been doing Civil long sections for too many years, 40+. When you drape a 2d pline on a surface it looks at all the intersecting 3dfaces or TIN edges. It does not do actual say 10m spacings, but good long section software has 3 choices do 10m spacing, NS only or combo of both. The same applies to the cross-sections. when you add design control the choices become more critical about the final output.
I started as a CIVIL software rep back in the 90's and software at that time was way more advanced than where Bricscad is at the moment, it needs a significant purchase of a CIVIL software company to catch up and be better than CIV3D.
This is an old plot youtube V16 its now V26. Shows some of the power of the software.
0 -
Oops, I misread the post, I thought Aridzv was looking for a lisp. I’m beginning to understand why civil software is expensive lol
0
