All new objects are hidden
Hi.I'm a newbee in Bricksys.I'm using version 8.2.11I opened a drawing, that I have been working with, a couple of days ago.When i now try to add a new object. A line, text box, what ever, on any layer, the object gets hidden when I press "Save". I have to select the object, for it to show again. The new object, do not show on the plot either.I tryed to select all objects, and pasted into a new drawing. Then the new objects showed up, but all the old objects got hidden....Do anyone know what I may have messed up here?
Please attach the drawing to a support request and add a description of what goes wrong: we'll be glad to investigate the cause.
Found a dirty sollution.I just copied the objects, to a new drawing, one by one(Groups), and now the drawing works ok.Maybe the file was a bit corrupt??
- Is it possible the current view is clipped, and the active z (elev) places objects outside the clip zone?2. Is the current layer off? Sorry, may be a dumb question but gotta ask 'cause I've seen that before too.
Scratch question #2.O/T: Sucks you can't edit your posts here.
I was having a quite similar problem in V8, while few if any others had it.I suspect if you changed to V9 the problem would go away as it did for me.
