Ubuntu 9.04
HelloI would like to know how to configure Bricscad on LInux 9.04.I have tried both packages .rpm and tgz and it did well succeed!By the way I tell you that I am still newbie on Linux sistems and certainly and making something wrong.I am anxious for a solution, will someone help me pls?thank you allNivande MachadoBrazil
Not sure from your post if you've installed it or not but article 70 in the Bricscad Knowledge Base gives brief instructions. Once installed run it with/opt/bricscad/icad
Andyhow can I find article 70?http://www.bricsys.com/en_INTL/support/knowledge.jspi am not really understand how to use this Knowledge baseis here any help how to use it?
The searchable Knowledge Base itself is at http://www.bricsys.com/common/knowledge/list.jspfor the English version, topic 70 is athttp://www.bricsys.com/common/knowledge/topic.jsp?id=255
thank you very much:)finally I got it
