Flatten command not producing result
Hi,I am working on Bricscad 9.2.15 version and trying to use FLATTEN command, for reducing the 3D Solid model to 2D but it does not work, it works only on entities which are assigned with elevation for example a Rectangle drawn with elevation. What should i do to flatten a solid model.Thanks in advanceSanjay.
