location bars
is possible to save the posittion of the toolbars? i use several toolbars position according to the drawing, sometimes i use more toolbars for 3D design and another times i work only in 2D design.
You can use User Profiles for this purpose. A user profile remembers which toolbars are open at which position. Choose User Profiles in the Tools menu to manage your user profiles. Place a shortcut to userprofilemanager.exe on your desktop to launch Bricscad using the profile of your choice.
Toolbar positions are stored in the registry in the current profile. If you create different profiles, e.g. 2D and 3D, you can launch Bricscad specifying the profile as a command line switch (/p 2D or /p 3D ) and it will start up with the desired toolbar layout.
