Search-Function in this forum
is there a possibility to search this forum also by way of google?
or do I HAVE to use the search-field here in the forum directly?
Thanks, Stephan
  • I think this, and adding your searchterm, is about as close as you can get for searching the forum by way of google.
    Or a bookmark with keyword helps for direct access from your browser.
  • Thanks for the reply, Ignace!
    What I don't like is the fact that with site:bricsys.com I get other results also (not forum only).
    I therefore tried site:bricsys.com/common/support but with that approach the result is missing out on many forum-threads altogether.
    So I guess your suggestion IS the best available solution, although not optimal.
    Thanks.
  • Thank you Gerrit!
    This is an excellent Idea! I made it even better in putting your suggested phrase into double quotes ("). This way even the beginning of the title is basically always shown in the results, giving me a better overview, what each search-result is about.
    Thanks to both of you, guys for the good team-work.
