Commandline switch in menu
Hello all,
I have a customized menu item, carrying following command:
^c^c^c(startapp (findfile "c:\\folder1\\folder2\\Program.exe"))
If I want to start Program.exe with a commandline switch, like : Program1.exe /switch,
is there a way available to put this in the menu?
If not, is there a workaround?
TIA,
Arno van Eeuwen
Arno, have you tried placing a commandline switch as a second argument to startapp?
For example:
(startapp "c:/program files/bricsys/bricscad v9/bricscad.exe" "/p profile2")
does successfully start the bricscad app for me with the profile2 active.
That's exactly what I needed.
Thank you, Greg.
