print preview problem with non-standart paper size
I have a drawing with size about 600*1500мм and 36inch roll paper in plotter.
I try to print it in scale 1:1 with "custom" paper size, for example, 650*1550mm, from "model" layout.
In "Page setup" dialog (_pagesetup) I've set PLOTTER (HP DJ 4500) and its new paper size (Custom1: 650x1550mm),
set window limits, scale 1:1, etc., and try to "Print preview" with button from this dialog.
The result: paper size (Custom1: 650x1550mm) automatically is changed to standart (Custom1: 11*17in)
and print preview picture is incorrect.
The same result I see in "Print" dialog (_print) after "Print preview" button.
But if I set my print settings in "Page setup" dialog without clicking "print preview" button,
and then run "Preview" command (_preview) from menu - the preview window is correct.
Also I don't see this problem if not trying to set custom paper size and use standart (A0 etc) size.
I think that problem is in "dropping" custom paper sizes settings when trying to "preview".
Please enter a support request about this issue and we'll investigate it.
Kind regards, Alexander Van Heuverzwyn
