Leading zero in angular dimensions?
Does anyone know if I can est something in a dimension style to label angles using degrees minutes and seconds so the minutes and seconds are always displayed as two digits? I currently have dimension styles that display the degrees minutes and seconds but the minutes and seconds are only shown with one digit if they are < 10.
Thanks
You can set Dmi angle precision to show 0d00'00.00"
Thanks for the reply. I see that will increase the decimal precision displayed.
I am trying to display angles so the minutes and seconds are always two digits. Currently I get 5°6'7" but I want to have 5°06'07"
Unfortinately it seems that you cannot do this in Bricscad.
I think you are right. It appears from another forum other some CAD applications are similarly limited in formatting angular display.
Thanks for the reply!
