Insert Raster Image - Set Preferences
I commonly use "Save as JPG" image from Google Earth to draw site plans.
Is there a way in the "Attached Raster Image Window" to have the default PATH set as a relative path, instead of "No Path" or "Full Path"?
I alway store the images in the same folder as the DWG.
Thanks,
Steve
If you store the image in the same folder as the dwg you should use "No Path". When you reopen the drawing BC will first look for the image in the dwg folder and then in the search path.
