A couple of points...
Firstly, the command line for the fillet command does not have "Radius" as one of the options a.k.a autocad.  I have noticed however that this is implemented, it just isn't shown!
Secondly, can bricsys look at a way to increase the sensitivity of selecting a solid hatch?  Hans previously told me that the selection point is somewhere on a triangulation constructed within the bounding polygon. I find this is difficult to hit at the best of times; Autocad on the other hand seems to have a true point in polygon test which seems to trigger regardless of where one clicks. I frequently have solid hatches as backgrounds but cant select them due to the amount of detail that is shown in the foreground.
  • Thanks for informing us about the not-displayed Radius option, we'll correct that.
    Please try the following: draw a rectangle, e.g. twice as wide as it is high, and hatch it using the solid pattern. To select the solid hatch in Bricscad, the cursor will have to be positioned on the diagonal running from top left to bottom right corner.
    Now do the same on Autocad ( I used v2008 and v2010). If SelectionPreview is on, you will notice quite easily that the solid hatch is only selected... if the cursor is positioned on the diagonal running from top left to bottom right corner.
    Please let me know if this is different from what you experience.
