grips
Hi there.
I have a problem with displaying grips in the drawings. If I select an entity they are shown, but if I pan the scene, they are lost, even the entity is selected. In the plan view is it OK, but in the pespectiv view is not.
What can I do to see the grips?
Thank you for answare
Thanks for drawing our attention to this regression, which got introduced during work on SR19795. This concerned not-visible grip points when the Z-coordinate of the view target point of the active viewport had a negative value. We will review this fix and correct it.
V9.3.10 has been published an hour ago, it includes a fix for the problem you reported. Thanks again for your valued feedback!
Thanks for an info.
I just downloaded and instaled, but it looks like before :-( www.3dvizualizace.cz/obrazky/grips.jpg
And more I get - default toolbars and aliasies. My configuration is gone :-( . Where I can find it?
Thank you
sorry bad link : http://www.3dvizualizace.cz/obrazky/grips.jpg
I replace default.cui and default.pgp with an older files and its working well.
Grips: could you please file a support request and attach a drawing as well as a concise description of the steps to take to reproduce it? We will be glad to investigate the cause and work on a fix.
picture is on link at #5 answare. The box is selected, but grips are gone. But now its OK. I don`t know, what hapened, but now it`s working OK.
But it`s new from version 9.3. I need to save default.cui and default.pgp and after instalation replace new ones because of my toolbars and aliases.
We've seen the picture, but we cannot reproduce the problem, that's why I asked for the drawing...
We are preparing a Knowledgebase article describing the preferred strategy to preserve customizations to cui files when upgrading.
Please have a look at: http://www.bricsys.com/common/knowledge/topic.jsp?id=276
Here is the dwg file with simple box I can not see grips.
www.3dvizualizace.cz/obrazky/grips.dwg
www.3dvizualizace.cz/obrazky/grips.zip
Please be so kind to use our support request system if you want Bricsys analysts to investigate your problem, the support request infrastructure was made for it and allows us to process problems much more efficiently. In other words: it allows us to process more problems in less time, that is: provide you with faster replies and allow us to have more time left for development.
Thanks for your understanding.
The user forum is meant for communication between users.
OK
