pat-files
Hi!
Is it possible to load own pat-files (like lin-files)?
The help screen for v9.2.15 says custom PAT files aren't supported yet.
But you can use your own file instead of the one supplied by Brics: name it "default.pat" or "iso.pat" (whichever you use, as controlled by the MEASUREMENT setting) and put it in the user support folder.
Or you can just add all your custom hatch patterns to the end of the existing "default.pat" or "iso.pat".
