From not available in ESNAP
Hi i was using Esnap while doing some drawings and could find "FROM" is not available in ESNAP can anybody help me out with this
Thanks Sanjay.
Dear Sanjay Jamalpur,
In BC7 icadbrx.lsp contains this function:
; function to simulate 'from' option .
; This should be a function, calling command 'c:from' transparently won't work
; it can be called with an accellerator(menu>customize>accelerator tab>new accelerator)
; or by typing (from) on the commandline during a command.
(defun from ( )
(setvar "LASTPOINT" (getpoint "\nBase point: "))
;enter an offset point with @ or using distance in direction of cursor
(getpoint "\nto point: "(getvar "LASTPOINT"))
)This works just fine.
Regards, Roy.
For your information: the FROM snap option will be added in the coming months.
Please read the 'Enabling From or Refpoint' topic under User Guide > Drawing Accurately in the Bricscad Help.
