pick objekts
How can I pick objekts, if one lies on top of the other (Strg in Autocad)?
  • At present this is not yet possible. However, if only two entities exist on top of each other you can select the bottom one by first using the window overlap method to select both entities, then press the shift button and click the top entity, which will leave the bottom one selected only.
  • Support for the Shift-Spacebar key combination to start/stop object cylcing during selection is scheduled to become available in a month or two.
    Kind regards.
