anybody interested in GEOMCAL?
Just out of interest  I started to program a geomcal clone yesterday, and I am already halfway done. The program will be compatible to Autodesk's GEOMCAL, but I don't know yet wether I will implement all geomcal functions. You can call CAL from the command line and enter a mathematical expression directly, and you will be able to use a (CAL "<expressionstring>") in your Lisp applications in BricsCAD and AutoCAD.
  • I used to look for CAL but have created replacements for most uses. It is interesting though.
  • Dear all,
    can anybody provide me with a legal geomcal version which is compatible to Bricscad V15? I have seen the comment from Thomas that it is no longer available, but maybe somebody had downloaded a legal copy before.
    Best
    Sebastian
  • Hello Sebastian,
    I sold the copyright for my app CADCAL to Widemann Systeme GmbH in Wiesbaden (http://www.widemann.de/). If you are lucky they will give you a copy. All GEOMCAL functions have been implemented and some other functions too. Since it is pure LISP it should run on all versions of BricsCAD.
    Best regards
    Tom
