1/ Is possible change order of icons in toolbar (have icons 1, 2, 3 ...etc and I want make 2, 3, 1 ...etc)? I try it change by drag and drop, or with pressed ALT or CTRL key, but no effect.
2/ I have undocked Layers toolbar, default is horizontal oriented. I want it have as vertical toolbar, but undocked. How?
1/ This is currently not possible. You have to delete an item and insert a new one at the correct position. Drag and drop would indeed be a nice feature, we will add it as soon as we can.
2/ This is also not possible. Support floating toolbars with multiple rows is on our todo list, so then a vertical floating toolbar will be supported as well.
Thanks.
1/ I open CUI directly in text editor and change it here.
2/ used to work in ver6 ! (FYI)
