3D Mirror
Has anybody else had trouble with 3d Mirror in the latest version and found a workaround. It appears that when you try to mirror in 3D, whether the mirror plane is XY, YZ, ZX or 3 point, the object is correctly mirrored and also mirrored about XY plane at Z = 0,00.
I have submitted a support request, I'm just hoping that somebody might have a workaround.
Regards
Rick
  • I can't duplicate your problem. All works just fine using Bricscad latest issue. I've tried all the variations, but with no problems. You can also mirror 3D entities using 2D mirror. Does 2D mirror not work for you either?
