Problem running Applications in Restricted Priviledges environment
Hello,
We have installed Bricscad V9Pro in a domain comptrolled network were draftsmen have limited priviledges, especially, to avoid propagation of viruses they can not install software, only an administrator can.
Bricscad runs perfectly, however, we have encountered a problem with the first 3 applications we have attemted to run on this system, DocTabs, Sofoco Tools, CivilCad. The programs run perfectly in administrator user, however, when moving to a limited priviledges user, the typical draftsmen user account, the programs will not run.
Has anyone encountered a similar issue, if so, have you found a solution?
Best Regards,
José
you can google "BeyondTrust Privilege Manager"
other option could be (have to test) relocate some user files and folders using windows tweak to a partition you can control rights access.
or try this also "UAC Tool"
http://www.symantec.com/norton/theme.jsp?themeid=labs_home&header=0&depthpath=00
