CUI error
After upgrading to version 9.3.14 I keep getting the following when starting Bricscad: "Unable to load CUI file: Menugroup Bricscad already exists". Anyone know how to fix this? Thanks ahead for any input.
If you could enter a support request with more info, we'll be glad to investigate it and help you as soon as possible. (please attach the cui file)
It sounds like the menu file you're using has two folders called "Bricscad," probably because there's a "partial" CUI file attached to the main one and they both have a folder with that name.
Maybe you can edit that CUI file with the Customize command, deleting one of those two folders. If it won't let you open the main file even in the Customize window, you should still be able to open the "partial" file and delete the Bricscad folder from that, and then the main file should open o.k.
