AlignSpace command
I am using Bricscad V10.1.4 and could find its much improved in 3D solid modeling and editing but i would like to know where i can find the tool or command for aligning the viewport space in Layout.I used to do this in AutoCAD using Express Tools --> AlignSpace command.
Sanjay.
Sanjay: you may find ShiftVP usefull:
http://www.bricsys.nl/common/support/forumthread.jsp?id=10951 (post #6)
Note: only tested on 2D-drawings.
