Fehlercode: Invalid axis
After nearly 1 week of work on a comprehensiv HVAC-project suddenly an failure like "Ein Applikationsfehler ist aufgetreten, der Fehlercode lautet:Invalid axis"
occured, so that work on the drawing could not be continiued. The dwg-file that was left cannot be reopened with the WHERST-command and has a drastically
reduced datavolumina. (Beim Laden der Zeichnung trat ein Fehler auf:Invalid group code")
Can anybody help to save about 30 hours of work ?
We use Windows XP Professional and Bricscad Version 9.1.11 German
best regards
Peter Schriebl
  • First thing to do is find the .bak file, rename it temporarily and change its extension to .dwg.
    If the original file really is shredded, that might be the best you can do.
